Hi there. We are finding another installation problem in section 2 – Installation of the Heated Bed.
The documentation says...2.1 - Identify the nine holes in the top marked with a laser engraved “1”. These holes are where you’ll install nine #4-40 T-Nuts from below.
However, our base top only has one hole engraved with a "1". Does anyone have a picture of which holes are the right holes for the T-Nuts?
thanks!
T-Nut issue - not nine holes labeled 1 on the base top?
Re: T-Nut issue - not nine holes labeled 1 on the base top?
use your onyx or onyx insulator as a guide. that will allow you to see what holes need the t nuts. http://forum.seemecnc.com/viewtopic.php ... t=60#p7156
there are only 6 holes that will line up properly. 6 t-nuts is all you need. Ignore the labeled 1, i think that was for the phebe heat bed.
