Berrybot3D Magnetic U-Joint or TrickLaser Carbon Fiber Arms?
inventabuild
Post by inventabuild »
Has anyone compared the quality of their printouts from using the Berrybot3D Magnetic U-Joint (http://forum.seemecnc.com/viewtopic.php?f=54&t=1704) and the TrickLaser Carbon Fiber Tube Arms with Metal Ball Rod Ends (http://tricklaser.com/Carbon-Fiber-Tube ... M-CFTX.htm)?
Clearly these are both awesome ideas, but I want the best print quality so I'm wondering which one should I pursue?
Flateric
Re: Berrybot3D Magnetic U-Joint or TrickLaser Carbon Fiber A
Post by Flateric »
I own both and really it's more of a how comfortable are you with fabbing?
If you are comfortable with fabrication then I think the magnetic arms are the best choice, if not the trick laser arms are not really far off from the magnetic in print quality. You'd be very hard pressed to see a difference infact.
However I do believe the magnetic arms will wear better after extended use.
Return to “Rostock MAX”
