EEPROM configuration
jesse
Post by jesse »
Would someone please tell me how to configure the Rostock Max to enable/use the EEPROM for settings?
LorenOlepi
Re: EEPROM configuration
Post by LorenOlepi »
Enter M500 in the Manual Control area to store to EEProm
foshon
Post by foshon »
You can also check the bottom portion of the config.h file to make sure it is set up correctly. Look for this:
/** \brief EEPROM storage mode
Set the EEPROM_MODE to 0 if you always wan't to use the settings in this configuration file. If not,
set it to a value not stored in the first EEPROM-byte used. If you later want to overwrite your current
eeprom settings with configuration defaults, just select an other value. On the first call to epr_init()
it will detect a mismatch of the first byte and copys default values into EEPROM. If the first byte
matches, the stored values are used to overwrite the settings.
IMPORTANT: With mode <>0 some changes in configuration.h are not set any more, as they are
           taken from the EEPROM.
#define EEPROM_MODE 1
Purple = sarcasm
jesse
Post by jesse »
Thanks, I uncommented this line in config.h :
#define EEPROM_SETTINGS
How can I define the bed height from Repetier?
[img]http://i.imgur.com/CLGXvt1.png[/img]
Are you SURE you have the Marlin firmware installed?
Recent kits should have come pre-loaded with Repetier.
foshon
Post by foshon »
If you are using Marlin, why? I used to like it, and then I used Repetier. If you haven't tried Repetier you should. Hell, I even switched MAX's little brother over to it.
Purple = sarcasm
foshon wrote:If you are using Marlin, why? I used to like it, and then I used Repetier. If you haven't tried Repetier you should. Hell, I even switched MAX's little brother over to it.
What is Max's little brother? :?
foshon
Post by foshon »
It's my MendelMax 1.5+
Purple = sarcasm
jesse
Post by jesse »
geneb wrote:Are you SURE you have the Marlin firmware installed?
I'm using the firmware that came with the SeeMeCNC installer.
It works fine and supports the Smart LCD.
What I meant was, how do I set the bed height to EEPROM from Repetier-host? The goal is skip reflashing the firmware.
cambo3d
Post by cambo3d »
marlin does not support eeprom changes via repetier as far as i know. the rosoft installer has the old marlin firmware. The downloads page on seemecnc website doesnt even list the rosoft as an option anymore
that's why you need to be sure what firmware you are using. the boards shipped from seemecnc currently all have repetier firmware preloaded and it works with the lcd
foshon
Post by foshon »
The bed height is set using the z-axis MAX Travel setting in the EEProm. The pic you posted says Marlin at the top, make sure Repetier is set to talk to the correct firmware before you do anything.
Purple = sarcasm
jesse
Post by jesse »
It appears that the Marlin firmware is being autodetected by Repetier-Host.
I wasn't sure if the settings were different in Repetier-Host V0.85b.
This video shows the possible EEPROM settings as an associate array list.
[youtube]http://www.youtube.com/watch?feature=pl ... lr4#t=645s[/youtube]
I'll email SeeMeCNC about the new firmware
foshon
Post by foshon »
jesse wrote:It appears that the Marlin firmware is being autodetected by Repetier-Host.
It's on their download page, you want this one https://github.com/seemecnc/RepetierMAX ... master.zip
Purple = sarcasm
jesse
Post by jesse »
Which version of Arduino did you use?
Version 0.23 (that came with Rosoft) shows an error message about the .INO file format.
foshon
Post by foshon »
jesse wrote:Which version of Arduino did you use?
I believe you can just rename the .ino to .pde, you may want to make a backup copy the ino just in case.
Edit: Just verified the rename trick works fine, no need for backup.
Purple = sarcasm
Or you can just upgrade to 1. Whatever.
foshon
Post by foshon »
Polygonhell wrote:Or you can just upgrade to 1. Whatever.
Isn't there an issue with the AVRdude stuff being compatible?
Purple = sarcasm
There was an issue with earlier versions of repetier and marlin, neither would compile against the 1.X libraries, but that was fixed some time ago.
foshon
Post by foshon »
ic
Purple = sarcasm
Return to “Rostock MAX”
