I'm printing the 25 mm cube oversize with new trick laser arms. it is a new machine and I do have the pulleys set to 20 (plastic)
Do I need to change delta radius in the firmware like I did on the magnets?
tricklaser arms printing over sized?
Re: tricklaser arms printing over sized?
If your prints are slightly oversized on the X and Y axes with the new arms, then you should try increasing DELTA_DIAGONAL_ROD slightly and checking again. DELTA_RADIUS is for dealing with doming on the Z axis (center of platform is higher or lower than outer edges).
was the magnetic conversion still giving you problems?
It is a different machine...
I haven't seen the heat shield yet, when did you send it Cambo?
I didn't, you never sent payment. I figured you changed your mind.bplemmons wrote:It is a different machine...
Check your email..... My bad,sorry. Still want it
the firmware listed on the downloads page of the seemecnc website is already setup for 20 tooth pulleys. try that.
that 12.7 diameter isn't relevant for the delta drive 0 type, according to the firmware.
