tricklaser arms printing over sized?
bplemmons
Post by bplemmons »
I'm printing the 25 mm cube oversize with new trick laser arms. it is a new machine and I do have the pulleys set to 20 (plastic)
Do I need to change delta radius in the firmware like I did on the magnets?
Broose
Re: tricklaser arms printing over sized?
Post by Broose »
If your prints are slightly oversized on the X and Y axes with the new arms, then you should try increasing DELTA_DIAGONAL_ROD slightly and checking again. DELTA_RADIUS is for dealing with doming on the Z axis (center of platform is higher or lower than outer edges).
cambo3d
Post by cambo3d »
was the magnetic conversion still giving you problems?
bplemmons
Post by bplemmons »
It is a different machine...
I haven't seen the heat shield yet, when did you send it Cambo?
cambo3d
Post by cambo3d »
bplemmons wrote:It is a different machine...
I didn't, you never sent payment. I figured you changed your mind.
bplemmons
Post by bplemmons »
Check your email..... My bad,sorry. Still want it
bplemmons
Post by bplemmons »
cambo3d
Post by cambo3d »
the firmware listed on the downloads page of the seemecnc website is already setup for 20 tooth pulleys. try that.
that 12.7 diameter isn't relevant for the delta drive 0 type, according to the firmware.
Return to “Rostock MAX”
