new slic3r support material test
guanu
SeeMeCNC Staff
Post by guanu »
tested out the newest release of slic3r 0.7.2b so I can test out if we can finally print with support material... and we can! (kind of)... the support material is a cross hatch like infill, it works, but is not super easy to clean up... but it does work... which is a definate improvement... only thing that would make it better is if the support material was just a little bit farther away from walls... here's a cleaned up test from thingiverse for support material test
[img]http://www.guanu.net/seemecnc/support_test.jpg[/img]
Guanu
I also recorded the print on my ustream channel if you are just that bored to watch it...
kilroyo
Re: new slic3r support material test
Post by kilroyo »
Awesome!! ,, cant wait to try it out. Been hoping they would get some support material that 'works' put in..
