If you're considering getting carbon fiber arms, DO IT! I'm thinking about offering kits if there's some interest. Since I first got my MAX I've had a fair amount of issues with infill not touching the perimeter, and I've sanded those joints so many times it's crazy, lol. Sometimes a print would turn out good, sometimes not so good, and printing fast usually made it worse. And I like to print high resolution, and fast! I was scared to sand anymore and cause side to side play. So I finally made the jump and sourced the parts to upgrade to the delta arms. At the same time I also added a belt tensioner, upgraded to the EZStruder (which is great), and switched from 15 tooth to 20 tooth pulleys. Now I just need to add a fan to help with overhangs and bridging...
The difference in print quality print after print is just amazing compared to the aluminum u-joints that shipped with it. I think I've read that the newer units don't have the sanding issues that the early ones like mine did, but I LOVE the peace of mind knowing that's one less thing I have to worry about calibrating when I get some print issues now...
I had posted a listing to sell a kit http://forum.seemecnc.com/viewtopic.php?f=38&t=2175 for the carbon fiber rods but didn't get much interest, so in the open source ways I'm going to list the parts and instructional videos to just make them yourself if you'd like!
Hardware:
0.394" OD x .288" ID x 23.75" L Pultruded Carbon Tube (need 3): http://goodwinds.com/300139.html
--I chose those above because they were on clearance at Goodwinds... only 25 left right now though! But I think they have longer ones in regular stock. I'll have to get a measurement for the external dimensions of the ball joints, but the .288" was really close! I couldn't find that spec anywhere on the web, but had found the spec for the max width of the ball joint (10mm). So I pulled up the online image of it and blew it up really large on the monitor. I used a software based pixel ruler to get how many pixels it was at the widest part (around the ball), then the number of pixels around the smaller diameter I wanted to fit inside the carbon tube, and extrapolated the exterior dimension of the smaller shaft on the ball joint. I then converted that metric measurement to inches and found the closest thing that didn't require me to sand each joint and came up with 0.288" inner diameter!!
Traxxis ball rod ends (need 1 pack of 12): http://www.amazon.com/gp/product/B000BO ... UTF8&psc=1
And some bolts/washers/nuts from Fastenal (where I got mine), or some other source...
12 - M3x30mm
6 - M3 hex nuts
6 - M3 flat washers
24 - M4 hex nuts
Part 1 - Measuring/marking/cutting the rods to length:
[youtube]http://www.youtube.com/watch?v=Om3uXpzBRco[/youtube]
Part 2 - Attaching ball joint to carbon fiber rod
Ball joint holder Ball joint holder:
http://www.thingiverse.com/thing:37306
[youtube]http://www.youtube.com/watch?v=HcgiSfdw12M[/youtube]
Part 2 (continued) - Inserting ball into ball joint
[youtube]http://www.youtube.com/watch?v=Ev5TTdLCwA0[/youtube]
Part 3 - Installing onto effector (print platform)
[youtube]http://www.youtube.com/watch?v=WDzmMn30Vio[/youtube]
Part 4 - Installing onto cheapskate
[youtube]http://www.youtube.com/watch?v=g407VDjvhrs[/youtube]
Stress Testing, impressive results with Locktite Superglue as the adhesive!
[youtube]http://www.youtube.com/watch?v=0ffuAfe3Z5M[/youtube]
120mm/s snowflake vase print: http://youtu.be/cK9DonfdppE
.08mm layers.... yes 80 micron layers with 0.5mm nozzle!
[img]https://lh3.googleusercontent.com/-q4aO ... CN0221.JPG[/img]
[img]https://lh3.googleusercontent.com/-iept ... CN0219.JPG[/img]
[img]https://lh3.googleusercontent.com/-MvO0 ... CN9654.JPG[/img]
[img]https://lh3.googleusercontent.com/-DX1u ... CN9655.JPG[/img]
[img]https://lh5.googleusercontent.com/-aXHj ... CN9662.JPG[/img]
[img]https://lh3.googleusercontent.com/--_E5 ... CN9670.JPG[/img]
[img]https://lh5.googleusercontent.com/-3yAC ... CN9672.JPG[/img]
More pictures: https://plus.google.com/photos/10915024 ... ttqu-o7kRw
