Got EZ Struder mining its way into my filament and does not feed. Does not happen right away usually 5-10 min into a print. I'm using 235 C hotend (checked with thermocouple)
Steps are adjusted to my old Rambo 1 am using 1.75 filament. Yes it is some cheap ass shit from china or somthin'n but worked just fine in old extruder..
I have tightened up all the bolts to nothing is moving though I find there is resistance caused between the EZ Struder and the bowen tube. Though you can feed the filament through and cause the hotend to extrude plastic with the spring handle held.
The teeth on the ez struder are all gummed up with plastic..
I have read on other threads about this issue and the people where able to resolve it by tightening the shit out of everything (the mounts and the bolts to the step motor)! I have done so, to no avail
I am not very pleased with this mount (conversion mount to old spool holder) as it allows so much play on the step motor... Think I am going to have to build a bracket and mount it properly rather than this POS SeeMee provided...
Any suggestions would be greatly appreciated
Don S
