Polygonhell wrote:If you have a very large discrepancy in heights at the center and edge of the build surface, multiple mm's.
The odds are you have differing steps per mm set for X Y and Z in the firmware and the EEPROM, the settings MUST match.
If the disparity is small and they match then a small adjustment to DELTA RADIUS is probably required.
The pot values he refers to are the current limiting pots on the stepper drivers, they are set in the firmware, too low and the steppers miss steps, too high and the drivers over heat and the steppers miss steps.
Thanks for your answer, i will double check those settings values and see if works.
Luis G.
