Hello from the UK
hobbit666
Hello from the UK
Post by hobbit666 »
All all.
I'm Neil (aka Hobbit) and a live in sunny (well at the moment it is) Wales in the UK.
I really really really ... etc want to build my own 3d printer and like the Rostock design. But can't find suppliers for some of the parts like the RAMBo boards :(. Anyway that's for me to solve lol
Thought i would just say Hi from over the pond :)
Also a quick question on the building what material is the base/table made from and what thinkness? i've found a company local that will Laser cut the parts for me.
Also as a side note are DIY 3d printers a bit of a catch 22? As most plans i have downloaded come with the STL files for all the parts but yet you need a 3d printer to print them lol.
JohnStack
Re: Hello from the UK
Post by JohnStack »
The melamine is .265 to .267" depending on where I measure. I live in southern California.
You're money ahead for the full kit.
http://dropc.am/p/KhiI1a
kbob
Post by kbob »
That's about 7mm in new money. You could probably use 6mm plywood* if you're willing to edit the CAD files. (Make all the slots thinner and all the tabs shorter.) It might even come out better than the melamine version -- plywood is stiffer. Or give it a few coats of polyurethane to get it up to thickness.
Ultimachine.com sells RAMBo. I don't know whether they ship to the UK.
* Am I right? Is 6mm a standard thickness in Wales and the rest of the EU?
hobbit666
Post by hobbit666 »
Yeah looks like 6mm or 9mm is the common sizes.
I'm not going to buy a kit :( as i'm planning to spread the cost over 4-6months and build it bit by it. So it's going to be a full DIY project.
hobbit666
Post by hobbit666 »
Out of stock at the mo but looking at shipping terms they do ship all over but warn on import tax etc etc
Might just use a RAMPS for the first build as I can get it off Ebay with the motor driver thingy's
hobbit666
Post by hobbit666 »
is this "melamine" stuff plastic? or is it a wood?
Trying to get some quotes for the laser cutting.
lordbinky
Post by lordbinky »
Melamine board is particle board with paper laminated to it with melamine resin ( which is made from melamine & formaldehyde).
Thinking on that, I wonder if formaldehyde melts PLA.
hobbit666
Post by hobbit666 »
Cheers for that, we do have a similar thing over here but looks like i need to edit the CAD files. Will start a new thread for that as i need to check i few things (been a while since i've done anything engineering wise
