PTFE tubes
PTFE tubes
I warped, ruined and split my PTFE tubes and wanted to replace both of them. Ware can I get a replacement please.
Re: PTFE tubes
Rostock MAX uses PTFE tubing in three places.
SeeMeCNC also sells tubing for the Bowden tube.
http://shop.seemecnc.com/Teflon-Tubing- ... gs_c10.htm
- The Bowden tube is PTFE.
- The thermistor leads are sleeved in PTFE.
- The hot end resistor leads are sleeved in PTFE.
Re: PTFE tubes
eBay has them too but not transparent
Re: PTFE tubes
It doesn't need to be transparent to work
Re: PTFE tubes
I did not realize that. I am talking about the tubes inside the hot end.
Re: PTFE tubes
You know that the outer PTFE tube in the hot end is split on purpose, right?
