Alright, thought I would try printing the test cube once I got the extruder direction fixed. So I follow the instructions and import the test cube, then slice it, then eventually click run job and nothing happens!!! WHAT?!? lol It's like the tv cutting off before the end of the movie. Anyway... I suppose the usual question is in order: any suggestions?
Thanks for all the support!
Run job command
Re: Run job command
Do you see the G-code in the right-hand window after you slice? Is Repetier Host connected and you can home it from the print panel?
Re: Run job command
Yes to both. Still not sure what is happening. Is there something in the configuration settings when I set up the repetier/slicer settings that would cause this? It just seems strange. What about an issue with manual control vs letting the G code for the sliced file work ?
Re: Run job command
The easy thing to do is try a different slicer or two.
