Anyone know how to change the annoyingly loud clicky/pop/bleep sound that RFirmware makes whenever you use the LCD menu?
It makes me angry and feeling kind of stabby. :/
BLEEP BLOOP
Re: BLEEP BLOOP
Take a needle, kill the tiny speaker....
Actually, that's a page from my past when a crazy kid I knew (not me) would go around to any speaker he saw and would poke the tweeter with a needle.
Are you willing to reprogram? There's no config for it from what I can see.
http://dropc.am/p/KhiI1a
Re: BLEEP BLOOP
In firmware you have to change
#define FEATURE_BEEPER true
to
#define FEATURE_BEEPER false
in configuration.h
if you do a search for the word sound it takes you right to section, that word is only used once in the config file.
to
in configuration.h
Re: BLEEP BLOOP
<<<<<<<awesome! thankx!lordbinky wrote:In firmware you have to change
to
in configuration.h
Re: BLEEP BLOOP
If you want to change the tone, look just slightly further down in Configuration.h. You can change the value of BEEPER_SHORT_SEQUENCE to change the sound.
What's more, you can test different sounds by sending a magic G-code. My printer is in the middle of a long job, so I can't test this, but I think the command is "M120 S<delay> P<repetitions>". To generate the normal beep, you'd send "M120 S2 P2".
I would expect parameters something like 5, 1 to be quieter than the current chirp. I'll try it when this print job finishes.
Re: BLEEP BLOOP
Yes, M120 emits a tick. To my damaged ears, parameters 1, 1 makes the quietest tick.kbob wrote:If you want to change the tone, look just slightly further down in Configuration.h. You can change the value of BEEPER_SHORT_SEQUENCE to change the sound.
So try this on for size.
M120 S1 P1
#define BEEPER_SHORT_SEQUENCE 1, 1
