Apparently 0.05mm is considered by others to be an acceptable target. In the post hercek describes that within 3 attempts of the hall-effect leveling probe on Johann's Kossel they were within 0.05mm. He also describes the general method for measuring the bed and adjusting tower positions in the firmware (which I hope might help with my issues).Polygonhell wrote:You have to put the error in context of the machine..
If the reading is off by say 0.05mm it really only impacts the first layer since every subsequent layer is relative to it. You can see this when you level by hand, the limit switches probably aren't repeatable to better than 0.05mm, so you work with that much error on every run.
http://forums.reprap.org/read.php?178,2 ... msg-238009
