We wanted a way to cleanly move the extruder and head wiring up top to support two top mounted extruders without a huge bundle of wires. We went with the Trick Laser top mount extruders but it could be used with the SeeMeCNC versions as well.
I whipped out a simple set of boards on our CNC mill that condense 2 sets of heater power, extruder motor, thermistor and a 2 wire auxiliary connection to two 26 pin ribbon cables. The heater connections use 6 parallel wires each. The motors use 2 parallel wires each and the thermistor and AUX connections one wire each in the ribbon cable. For typical #26 conductor ribbon cable this give the equivalent of somewhere between a #18 and #19 conductor. Total length of the ribbon cables is just short of 4 ft. We had to make up a couple of jumpers to go from the RamBO board to the bottom side extender board mounted in the unused bay between the Y and Z towers. Connections are either standard C-Grid connectors and terminal blocks so everything is simply wired 1 to 1 with the existing wiring.
Preliminary testing shows that the hot end and extruder motors work just fine and reach temperature without problem. We haven't noticed any conductor heating but will monitor it the first long duration print.
Photos tell a better story. The is still some copper on the corners of the top board where I had to mill the top copper away and didn't quite get the depth right.
[img]http://www.celeritous.com/Public/Top_Board.jpg[/img]
[img]http://www.celeritous.com/Public/Top_End.jpg[/img]
[img]http://www.celeritous.com/Public/Base.jpg[/img]
[img]http://www.celeritous.com/Public/Full_Length.jpg[/img]
If it works out well I can supply Gerber and drill files to anyone interested or provide it in DesignSpark format (We don't do Eagle - sorry)
Top Mount Extruder Wiring Extension
Jump to
- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- Software
- ↳ Orca Slicer
- ↳ SuperSlicer
- ↳ Cura
- ↳ Simplify3D
- ↳ Slic3r
- ↳ KISSlicer
- ↳ Repetier Host
- ↳ OctoPrint
- ↳ Other
- ↳ Sculptris
- ↳ OpenSCAD
- ↳ FreeCAD
- ↳ Blender
- ↳ SolidWorks
- ↳ AutoDesk 123D
- ↳ EMC2/LinuxCNC
- ↳ Skeinforge
- ↳ Mach3 Software
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
