I'm currently rewiring my Rostock MAX with EZstruders in a dual extruder setup.
Got the kit with new hotends and all.
I've got some 40W heater cartridges I am planning to use instead of the heating resistors.
Question is if I should put two in each of the hotends?
gallenat0r
Extruder heat source
Re: Extruder heat source
You should use only one cartridge per Hot End.
- Plasticator
What should the configuration be like?
ØOØO
OØOØ
OØØO
ØOOØ <- I'm leaning towards this one where the cartridges are on the outer edge.
gallenat0r
ØOØO
OØOØ
OØØO
gallenat0r
I would lean towards that one also. It really doesn't matter because I would choose whichever one results in the best routing of the wires.gallenat0r wrote:What should the configuration be like?
ØOØO
OØOØ
OØØO
gallenat0r
I lean towards the one you did because I think it would look the best to me but it may be that a different one makes the wires easier to
route. Same goes for the thermistor and its wires. Happy building!
