is there a extra connection on rambo for fan
iam looking for a way to plug in a extra fan for extuder motor on rambo board lost my instuction sheet. see that there is a extra 5v connector on board but not to sure how ya control it any one know
Re: is there a extra connection on rambo for fan
If you want to run a 5V fan all the time, just grab a red and black wire off the power supply and do it that way.
just saw that my fan that i got is 12 v lol
If you are talking about the two pin connectors, there should be two of them, labeled on the schematic as Aux Power connectors.spart wrote:iam looking for a way to plug in a extra fan for extuder motor on rambo board lost my instuction sheet. see that there is a extra 5v connector on board but not to sure how ya control it any one know
One will provide 5 Volts, the other will supply the voltage equal to the input voltage (normally 12 volts). As far as I know you
cannot control these Aux power connectors from the firmware, they are always on. They can be used for a 5 volt fan the other
for a 12 volt fan but these fans will always be on when the Rambo is powered.
The Rambo wiki is here: http://reprap.org/wiki/Rambo
thanks i will give them a try
- dsnettleton
Or do what Gene said with a yellow wire instead of red.
Trust me, sir. I'm a wizard.
