is there a extra connection on rambo for fan
spart
Post by spart »
iam looking for a way to plug in a extra fan for extuder motor on rambo board lost my instuction sheet. see that there is a extra 5v connector on board but not to sure how ya control it any one know
Re: is there a extra connection on rambo for fan
If you want to run a 5V fan all the time, just grab a red and black wire off the power supply and do it that way.
spart
Post by spart »
just saw that my fan that i got is 12 v lol
spart wrote:iam looking for a way to plug in a extra fan for extuder motor on rambo board lost my instuction sheet. see that there is a extra 5v connector on board but not to sure how ya control it any one know
If you are talking about the two pin connectors, there should be two of them, labeled on the schematic as Aux Power connectors.
One will provide 5 Volts, the other will supply the voltage equal to the input voltage (normally 12 volts). As far as I know you
cannot control these Aux power connectors from the firmware, they are always on. They can be used for a 5 volt fan the other
for a 12 volt fan but these fans will always be on when the Rambo is powered.
The Rambo wiki is here: http://reprap.org/wiki/Rambo
spart
Post by spart »
thanks i will give them a try
dsnettleton
Post by dsnettleton »
Or do what Gene said with a yellow wire instead of red.
Trust me, sir. I'm a wizard.
