68377 TSLOT SUPPORT
Here's where you can find the official (and unofficial too) things like assembly instructions etc...
Tincho85
68377 TSLOT SUPPORT
Post by Tincho85 »
Hello guys, I think I've found a problem with the WOOD RMAX EZ SHEETS files.
The "68377 TSLOT SUPPORT" seems to be wrong. I still haven't build my Rostock yet, but was checking the laser cut tolerances when found this.
If someone could check this would be great.
Here are some pics, images speak better than words :P
Martín S.
Tincho85
Re: 68377 TSLOT SUPPORT
Post by Tincho85 »
The 3 supports
The 3 supports on top of each other
Close up
68377 03.jpg (33.27 KiB) Viewed 4978 times
Martín S.
Toyguy
Post by Toyguy »
Gene notes this in the manual. Those rounded areas don't impact anything, the fact that they are different is merely cosmetic. Do a dry fit of the components and you'll see what I mean. Mine were like that too.
Dave
Tincho85
Post by Tincho85 »
Toyguy wrote:Gene notes this in the manual. Those rounded areas don't impact anything, the fact that they are different is merely cosmetic. Do a dry fit of the components and you'll see what I mean. Mine were like that too.
Dave
My mistake for not reading the manual.
Thank you Dave.
Martín S.
Return to “Rostock MAX Official Docs”
