I'm starting through the calibration process in the Assembly Guide and am generating some questions. Any insight into these would be helpful...
1. When using the Z manual control arrows in Repetier-Host, the motion up and down is quite slow. Is that normal? When Homing the carriages move quite quickly, so I am guessing this is just something Repetier-Host does, but wanted to be sure.
2. Does the mentioned Home-X and Home-Y button bug still exist in the 0.90c release of Repetier-Host? It would be nice to have those working. On a related note, do the unlabeled Home (Home All?) and the Z-Home work correctly?
3. When tuning the hot end PID, the process completed successfully, but I noticed the PEEK fan never came on. Should that have been on or does the Autotune not use it? Is there a simple way I can test the fan?
4. When tuning the heated bed PID, should I do so with the glass plate on or off? Make any difference in the PID calculation?
5. While the hot end was coming up to 200C during the tuning process, I detected a small stream of smoke from around the nozzle end. I watched it very carefully and could detect no burning insulation, nothing touching the hot end that I could see. It stopped after a brief period and did not reappear while the tuning process continued. I'm hoping maybe just some oil or something on the metal bits but has anyone seen this before? I am wondering if I need to disassemble the hot end.
Thanks, and Happy Thanksgiving for those partaking!
Dave
