Hardware needed to convert a Rostock MAX to dual extruder
laurent
Post by laurent »
Hi,
I am thinking about buying a Rostock MAX but I would like print forms that will require support (using HIPS) so I would like to convert it to a dual extruder printer.
What additional hardware do I need to order to make the conversion?
Or is this a bad idea and I would be better of order a printer that supports dual extrusion out of the box (like http://www.ff3dp.com/#!creator/c1txh)?
Thanks
cope413
Re: Hardware needed to convert a Rostock MAX to dual extrude
Post by cope413 »
You'd need an extra extruder motor (and extruder), hot end, and possibly a new effector plate depending on which hot ends you decide to use. You would also need a couple of ptc connectors and another length of Bowden tube.
dpmacri
Post by dpmacri »
SeeMeCnc sells the "add-a-struder" kit that provides everything you need except for the effector plate. I have one of the kits but haven't finished putting it together, yet! :-)
laurent
Post by laurent »
artexmg
Post by artexmg »
I'm just going down that path.
I bought the Dual hot end from tricklaser and the extra ezstruder/hot end kit from Seeme CNC. Here is a picture of my current setting. You can see that I have a Steve's Struder as my Rostock is an "old" one (ordered by end of February)
I'm still waiting for the dual extruder to arrive!
Rostock Max with Extra EZ Extruder
Nylocke
Post by Nylocke »
Nice acrylic MAX :)
artexmg
Post by artexmg »
Nylocke wrote:Nice acrylic MAX :)
It looks nice, but it was a pain in the neck when building, as I broke several pieces when tightening the screws. By the way, thanks to CNC guy's for providing the spare pieces :-)
Return to “Rostock MAX”
