Display Question
Capt Jack
Display Question
Post by Capt Jack »
Should my LCD display show something even if the firmware isn't installed yet? I turned on my machine for the first time, and the display is blank, as if it isn't getting power. I may turn the cables around on the Rambo, even though I'm sure I have them facing the right direction.
Suggestions?
~Capt. Jack~
Capt Jack
Re: Display Question
Post by Capt Jack »
Well, I had it backwards. LCD lights up now!
But, I can't get it to display anything.
I'm a complete NEWB to all this Rambo/Repitier/Marlin stuff.
I did do the Ardunio, and I can control the unit from Repitier host, but I have know idea what to do with Repetier MAX folder and the Marlin folder!
Sorry, but help!
~Capt. Jack~
grasshorse
Post by grasshorse »
If you have a newer machine you ignore the Marlin firmware files. I only used the Repetier firmware files. If you have used Arduino before, you open the Repetier Firmware files like any other Arduino Project. Make sure that you have the most recent version of the Arduino IDE installed (1.5). It will automatically install drivers if needed.
I then followed SeeMeCNC's video for setup. Very detailed, very clear.
https://www.youtube.com/watch?v=r059aWPsoJ4
Hope that helps.
Steve
Rostock Max, Top Mounted EZ Struder (x1), Onyx Heated Bed, 1/8" Glass Build Plate ( Elmer's Disappearing Purple Glue Stick), E3D Hot End, 40W Ceramic Heater Cartridge, TrickLaser Carbon Fiber Arms, Host: Repetier, Slicer: Slic3r, Modeling: Blender
Repetier firmware supports the LCD screen out of the box, there are no modifications to make. Just load it and go :) It uses the newest Arduino software too.
Broose
Post by Broose »
I see the blocks on the LCD on my machine for a second or two on powerup just before the firmware boots. I don't know if the blocks are part of the startup or the default on powerup before the Arduino accesses it. I don't hear the clicking on rotating the encoder (digital potentiometer) until after it has booted up when the display changes. The top cable on the Rambo appears to control the display and the bottom cable, the encoder and reset button.
You can try this test blind to see if it will home through the lcd panel:
1) turn on system and wait a few seconds
2) push in encoder until you hear the click
3)rotate one click clockwise
4)push in encoder
5)rotate one click clockwise
6) push in encoder
now the machine should home.
cambo3d
Post by cambo3d »
If your positive all your wiring is right, it might be a bad lcd. I had the same problem.
you might have to send to seemecnc so they can check it, if its bad they'll send you a new one.
http://forum.seemecnc.com/viewtopic.php ... =160#p7856
Dust2Dust02
Post by Dust2Dust02 »
Update?
I am having a similar issue.
[img]http://forum.seemecnc.com/download/file.php?id=3067&t=1[/img]
cope413
Post by cope413 »
Are you both sure you're plugged in correctly? When the plugs are reversed (correct polarity, wrong port), you get power but no display...
Dust2Dust02
I will have to check tonight
int2str
Post by int2str »
The bars are the default "power on" behaviour for the LCD display. If it's not received any commands yet, that's what you get if you just power it.
When plugging in the 2 ribbon cables, make sure the connectors cover both rows of pins and that the connector is centered left/right across all pins. It's VERY easy to plug in only 1 row of pins or offset the connector left/right by a column or more.
Capt Jack
Post by Capt Jack »
As a (very late) followup, I had to send mine back to CNC. It was defective and they promptly replaced it free of charge. New one has been working flawlessly.
Thanks CNC!
~Capt. Jack~
Dust2Dust02
I may have to do this. I see this screen and it does not change. USB works fine so far. I click on the scroller thingy and it does nothing. I swapped the cables and the LCD went out. Swapped them back and just got the bars again. Oh, well, wasn't going to use it much anyway.
