quad extruder on Rostock Max
Re: quad extruder on Rostock Max
The RAMBo and most other controllers like RAMPS have extra output pins that you can utilize to use at the least 3 extruder so with some hacking. I was working on a schematic to use AUX-1 on RAMPS as an output for another stepper, thermistor, and MOSFET controlled 12v output for a hotend. I needed another outpu pin for it, but if I used AUX-1 and 2 I could get it to run 2 more sets of hotends, thermistors, and MOSFETs. The only board I know of that can handle more than 2 extruders is the Tricolor RepRapPro Mendel board. If you would like, I could finish the schematic for RAMPS and adapt it for RAMBo use and if you're any good with a soldering iron and if you can read a wiring diagram you could hack one together yourself
I would be interested in that schematic if you get a chance. Sounds like a darn good thing to do. Both the Rambo and Ramps if you have the time, Rambo especially if you only have time for one. Thanks for offering to do this.Nylocke wrote:The RAMBo and most other controllers like RAMPS have extra output pins that you can utilize to use at the least 3 extruder so with some hacking. I was working on a schematic to use AUX-1 on RAMPS as an output for another stepper, thermistor, and MOSFET controlled 12v output for a hotend. I needed another outpu pin for it, but if I used AUX-1 and 2 I could get it to run 2 more sets of hotends, thermistors, and MOSFETs. The only board I know of that can handle more than 2 extruders is the Tricolor RepRapPro Mendel board. If you would like, I could finish the schematic for RAMPS and adapt it for RAMBo use and if you're any good with a soldering iron and if you can read a wiring diagram you could hack one together yourself
pyrophreek
^second that. Would love to be able to control 3 or even more through Rambo. Also, I think the reprap trip color actually uses two boards. Do you think there is any way to add a breakout board to the Rambo to allow 4+extruders?Eaglezsoar wrote:I would be interested in that schematic if you get a chance. Sounds like a darn good thing to do. Both the Rambo and Ramps if you have the time, Rambo especially if you only have time for one. Thanks for offering to do this.Nylocke wrote:The RAMBo and most other controllers like RAMPS have extra output pins that you can utilize to use at the least 3 extruder so with some hacking. I was working on a schematic to use AUX-1 on RAMPS as an output for another stepper, thermistor, and MOSFET controlled 12v output for a hotend. I needed another outpu pin for it, but if I used AUX-1 and 2 I could get it to run 2 more sets of hotends, thermistors, and MOSFETs. The only board I know of that can handle more than 2 extruders is the Tricolor RepRapPro Mendel board. If you would like, I could finish the schematic for RAMPS and adapt it for RAMBo use and if you're any good with a soldering iron and if you can read a wiring diagram you could hack one together yourself
Ill work on the schematic later today then, Ill make one for RAMBo when I'm done with RAMPS. The schematic will be for Pololu Stepper Drivers, standard on RAMPS, so sorry but I'm not planning for any digipots for this, I don't even know if there will be enough expansion for it, crossing my fingers though
I think I can get enough from the motor extensions, PWM extension, and Serial Extension though hopefully
You know, for someone in high school you are one bright dude.Nylocke wrote:Ill work on the schematic later today then, Ill make one for RAMBo when I'm done with RAMPS. The schematic will be for Pololu Stepper Drivers, standard on RAMPS, so sorry but I'm not planning for any digipots for this, I don't even know if there will be enough expansion for it, crossing my fingers thoughI think I can get enough from the motor extensions, PWM extension, and Serial Extension though hopefully
Thanks, but I'm not as smart as I'd like to be
still so much to learn.....
ccavanaugh
And, it's apparent you are not afraid to try, learn, maybe stumble along the way and learn from it.
I've worked with many engineers of different disciplines, and many times I have encountered the types that are bound by what they can learn in a book or others tell them. Or, they are just too lazy to try.
You have a bright future...keep it up!
Thanks, you guys are great. I'm also working on a controller for 3 color LED's that change color based on heating state, RED if any heating elements are on, BLUE if any elements are off but hot, and GREEN if all heating elements are off and cool. Its for RAMPS/Marlin by default, but if anyone here has any interest, ill adapt it for RAMBO/Repetier too.
- barry99705
If it's plumbed correctly the odds of a leak are pretty damn slim. My old Mac G5 tower was water cooled from the factory, and it ran 24/7 for almost 10 years without a leak. It did finally leak, but I think that's my fault. A 3770 mile trip in the back of a frozen Honda Element was just too much for the water pump. Probably didn't help that I left on one of the coldest days I'd seen in a few years, it was -55F! We didn't see above zero temps until around Chicago. Was so cold and bumpy in places the acoustical coating in the spare wheel well shattered. So if properly installed, I don't see a problem sitting in a climate controlled room. It also wouldn't be too hard to put a solid cover over the electronics bay in the base. Hell, you could print one up with channels on the top to direct the flow to a safe area.dpmacri wrote:That part worries me the most. What happens when it starts leaking and water runs down onto your electronics!barry99705 wrote:I'm digging the water cooled part.
Hi all, Nylocke im very interested in the rambo mod to use 4 extruders, please let me know if yoo need some help to get this realized
