I read these two posts:
http://forum.seemecnc.com/viewtopic.php?f=54&t=2271 (The problem was the 5A nano fuse)
http://forum.seemecnc.com/viewtopic.php ... end#p20481 (The problem was a blown heater cartridge)
They were very similar to my problem - I am getting no heating on the hot end. I just installed a new 40w heater cartridge since the stock one started smoking an died (in a very similar fashion to this, minus the melting PEEK: http://forum.seemecnc.com/viewtopic.php ... nd+on+fire) but still no heating is happening. The thermistor seems to function correctly since it's been giving me the same idle temperatures as the build plate all day.
I noticed in one of the posts that there was mention of the red light near Heat 0 that is supposed to turn on. It does not turn on. The build platform light turns on, but not the hot end.
Any thoughts?
EDIT*
I'm getting 0.03 volts over the Heat 0 when turned on.
The fan doesnt seem to run either. 0 volts over it's connectors when turned on.
Very low voltage for hot end power
Re: Very low voltage for hot end power
If the LED under the Heat 0 does not come on when the Hotend attached to Heat 0 recieves a signal to turn on, it usually indicates a failure on the Rambo board.
I'm sorry to tell you that because it means you will have to get the board repaired or replaced. If you contact Ultimaker they will probably repair this card for you.
They are the manufacturers of the card. I don't know how long you have owned this card but it is possible that it is under warranty.
Before we go any further there are small fuses on the card (two of them) that fit into small sockets. You should pull out these fuses and check continuity of the fuse.
It is possible one of them is burned out. They can be replaced with the original 5 amp or you can put 10 fuses in there.
The part numbers from Digikey or Mouser are:
The original 5A fuse is
LittleFuse 0451005.NRL
The 10A version is
LittleFuse 0451010.NRL
They're both ~$1.50-$2 a piece in small quantities.
The 10A version is
Oh. I was afraid of this... I will check fuses now.... Actually it looks like one of them has blown, the one closest to the power. Hopefully this means I can replace and soldier on? I'm out to find some fuses. I read someone say that 10A is a better choice - thoughts?
I would use the 10 amp but they do not solder on. They plug into the little sockets.
Buy a couple of spares too, you will likely need them and they are cheaper because you
don't have to pay shipping each time. Use either Digikey or Mouser because they are an
uncommon fuse and it is unlikely you will find them in a local shop. After re-reading what
you wrote, you meant to solider on not solder on. My mistake. It is a high probability that
once you change the fuse the card will be fine.
Lol, soldier on, not solder on - that would be disastrous
Oh ok, I will order some now... Damn more waiting :/
Hey thanks for the help, glad you're around.
You are welcome. That's why I am here, I enjoy helping people.McSlappy wrote:Lol, soldier on, not solder on - that would be disastrous
Happy Holidays!
Looks like RS online has them as well with free shipping - unlike the $34 shipping of DigiKey.
Get them wherever they are the least expensive and when you do get them, leave us a note so that we know your problemMcSlappy wrote:Looks like RS online has them as well with free shipping - unlike the $34 shipping of DigiKey.
has been fixed.
By the way, I never welcomed you to the Forum and I try to welcome all new users to the Forum.
SO, Welcome to the Forum! We are a group of guys and gals that exist to share new ideas, help people with their problems
and generally just exist because SeeMeCNC was nice enough to provide us with this forum to help each other. Always come
to the forum if you have a question, a problem or an idea that you think other users can benefit from. We are a very diversified
group from the very young to the very old (like me) and we have all have very diversified backgrounds so we can usually get
the problems solved.
