mach 3 setup
martinezfrank95
- Plasticator
mach 3 setup
seting up mach3 with 4 axis to h-1 printer
martinezfrank95
- Plasticator
Re: mach 3 setup
i posted 2 question and no one has answer how can i get some help
Re: mach 3 setup
I looked through your posts, and I'm not sure how to help. Can you share more details and elaborate a little bit on the problems you're experiencing? You're having trouble with a heated bed also?
We'll get you some help mate, just let us know a little more about what you're observing and what troubleshooting you've already tried. The more details you share, the more likely you are to get a specific and relevant answer.
Re: mach 3 setup
I'm actually going to follow this close myself, only because I am curious how the arduino boards can even be controlled from mach3.
Something new to learn for me.
Re: mach 3 setup
He's trying to use Mach3 with the original 4 axis CNC controller based electronics for the H1.
You might want to search back in the forums, or drop SeeMeCNC a line they probably have a configuration that will get you started.
I never used the stock electronics on the H1 so I can't help.
wildideas1
Re: mach 3 setup
What is your .? My son and I run both H1 mach3 and rostock setup
Re: mach 3 setup
Unfortunely, I am a Delta rostock user and I could be wrong here but I believe that you cannot run this type through mach3 can you? Awsome if you can......please I am all ears and very anxious to learn.
martinezfrank95
- Plasticator
Re: mach 3 setup
i bought a h-1 with 4 axis controller put it together followed the mod the 4 axis board to spec install mach 3 on my computer with printer port and when i hit test on the program the printer makes a hissing sound but nothing happens.
Re: mach 3 setup
It was possible to run the H-1 printer using Mach3 but Mhackney used to be the resident expert but he is on the forum so rarely anymore I don't know how to get help for this
user unless he contacts support.
Re: mach 3 setup
Contact support at [email protected] with your questions. This product hasn't been offered in yearsmartinezfrank95 wrote:i posted 2 question and no one has answer how can i get some help
and users who used to know the H-1 printer are just not on the forum much anymore. I generally do not
send users to SeemeCNC support but you are not getting any answers because there just aren't any users
familiar with the H-1 Legacy printer.
