Wich is the best for me??
mirage1207
Post by mirage1207 »
Happy new Year to all :)
I want to buy your Delta printer, but do not know for what I decide. Orion or Rostock Max.I want this printer for my business use (http://www.franconiarobotix.com) because I have my robot arms some parts to print. Until now I use a Delta Micro UP!! Printer.
The most important thing for me is actually the printer can run standalone and especially the print is nearly perfect that I can also sell the things.
I have also not afraid to build the Rostock Max. I trust me to without problems! Furthermore, I would equal to a second extruder, etc to buy-I would like a dual prithead!
the software makes me I think no big problems ... when up! it's just very, very simply equal hinzubekommen a perfect print what I imagine a little harder at your printers.
which your two printers is simply better print results from her, printing area or speed are first secondary for me! The printer MUST ABS and PLA can print what they indeed do both ..
i hope you could help me!! :)
Re: Wich is the best for me??
mirage1207 wrote:Happy new Year to all :)
Happy New Year to you. If building the kit doesn't bother you then it comes down to a couple of questions you should ask yourself.
First, are you willing to spend the many hours building the Rostock Max or do you want the pre-assembled convenience of the Orion?
Second, do you need the much larger print area of the Rostock Max or can you do with the smaller print area of the Orion?
Once you ask yourself these questions and are sure of the answers you can make a better decision of what to buy.
Keep in mind that your needs may change in the future and the larger Rostock Max lends itself to more upgrades or "hacks" simply
because there is much more room to apply such changes. If you want the larger area of the Rostock Max but to not want to build it
you may check with SeeMeCNC or TrickLaser.com and see if they have a pre-assembled version and the price, if offered.
Return to “The Lounge”
