So I'm still working on the first version of the Rostock Max and I'm trying to set up the Arduino software. I set up the correct serial port and selected Arduino Mega 2560/ Mega ADK for my board. Then I clicked the upload button and this popped up in the error compiling.
core.a(main.cpp.o): In function `main':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/main.cpp:5: undefined reference to `setup'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/main.cpp:15: undefined reference to `loop'
Arduino Error Compiling
Re: Arduino Error Compiling
did you hit compile the button next to it first?
What version of the Arduino IDE are you using?
What firmware are you using? Where did you download it from?
You have not yet loaded a project into the Arduino IDE. See here.Druk Gyalpo wrote:So I'm still working on the first version of the Rostock Max and I'm trying to set up the Arduino software. I set up the correct serial port and selected Arduino Mega 2560/ Mega ADK for my board. Then I clicked the upload button and this popped up in the error compiling.
http://forum.seemecnc.com/viewtopic.php ... 588#p15588
- grimmindustries
Thank you, I had the same error and this fixed it.
all of you that use arduino - when i try to use it on my self build delta, it's work only with arduino 023 and didn't work with arduino 1.0.5
