Print fails about the same place each time..
TRAILtech
Post by TRAILtech »
I'm attempting to print a water bottle, the print stops around the same location roughly layer 298 of 1007. The extruder stops, everything just stops. No jam is occurring it's really strange.
Below is the code generated on the layer which is failing... I don't know much about G code, maybe you see something obvious?
17:16:05.667 : Printing layer 298 of 1007
17:16:05.678 : N282311 G1 X-18.447 Y37.984 E5.25917 F1440 *49
17:16:05.696 : N282312 G1 X-19.783 Y37.638 E5.34026 *92
17:16:05.701 : N282313 G1 X-25.203 Y35.62 E5.68018 *96
17:16:06.189 : N282314 G1 X-26.443 Y35.012 E5.7613 *101
17:16:06.258 : N282315 G1 X-30.313 Y32.898 E6.02047 *93
Re: Print fails about the same place each time..
It' probably the repetier bug.
You can try slicing with a slightly different layer height, and KissSlicer seems to be less likely to expose the bug.
TRAILtech
Post by TRAILtech »
I chnged my layer height to .21 from .2, and unplugged my LCD (Read this MIGHT have something to do with it...)
I'll let you know in the AM (Fingers crossed)
TRAILtech
Post by TRAILtech »
It worked! I'll never know if it was the LCD or the layer height thought... Might do a dry run to night with just the LCD disconnected.
TRAILtech wrote:It worked! I'll never know if it was the LCD or the layer height thought... Might do a dry run to night with just the LCD disconnected.
Glad that you got it to work and since you changed two things you are correct about not knowing which one fixed it. Please let us know if you find out.
