Slicer errors?
Talk about the Repetier Host software here (http://repetier.com)
Slicer errors?
Has anybody else gotten this error while using the Slic3r built into Repetier Host?
[img]http://i.imgur.com/ht8DxIm.jpg[/img]
Durandal
Re: Slicer errors?
Post by Durandal »
I got this error when I turned the nozzle Diameter down to .1mm.
foshon
Re: Slicer errors?
Post by foshon »
Yeah, slic3r failed, but RH is not programmed to pick that up.
Purple = sarcasm
summyman
Re: Slicer errors?
Post by summyman »
I just updated to the newest version of Repetier Host, VO.95D and I get this same error message when I try to slice with Slic3r. Did you figure out how to resolve this error? Any help will be appreiciated.
SDI
Re: Slicer errors?
Post by SDI »
i was offered the RH update today and declined due to my deep set, inherent fear of updates
JolietDelta
Re: Slicer errors?
Post by JolietDelta »
Hi!
I get this message after provoking an error in slic3er. Seems that RepHost has changed its kind of error handling. The faulty part isn't RepHost but a unsuccessfull slic3r session.
Strange: objects/settings which couldn't be sliced with the command-line edition of slic3r (which is used by RepHost), didn't fail with the UI-version of slic3r.
Besides that - I had no problems after updating RepHost.
-Jens
foshon
Re: Slicer errors?
Post by foshon »
I get it now that I've updated, yet Slic3r works very well. It's an integration issue of some kind. The cool kids are talking about it Repetiers Reprap forum sub-section.
Purple = sarcasm
Return to “Repetier Host”
