Pendant
Orenfor
Pendant
Post by Orenfor »
i found this Pendant in here :
http://www.thingiverse.com/thing:150709
and i try few times to print it. but never success , anyone know about any good slicer/ setting to use for print it ?
I try with Brim and Raft and support , seems that i fail all the times. and it's only 20 min printing.....
jmpreuss
Re: Pendant
Post by jmpreuss »
Orenfor wrote:i found this Pendant in here :
According to the comments it wasn't FDM printed, I am not sure it can be done with any settings.
int2str
Re: Pendant
Post by int2str »
I think you could print it upright with a raft.
Navkram
Re: Pendant
Post by Navkram »
I change the size and scaled it up 1.5 and in netfabb i chopped the bottom point off to have a little more contact to the bed and printed with ABS here is the pick still on my Orion. no support
[img]https://scontent-a-atl.xx.fbcdn.net/hph ... 0933_n.jpg[/img]
layer_height = .2
; perimeters = 1
; top_solid_layers = 5
; bottom_solid_layers = 5
; fill_density = .2
; perimeter_speed = 30
; infill_speed = 30
; travel_speed = 200
; nozzle_diameter = .5
; filament_diameter = 1.75
; extrusion_multiplier = 1.0
; perimeters extrusion width = 0.60mm
; infill extrusion width = 0.60mm
; solid infill extrusion width = 0.60mm
; top infill extrusion width = 0.60mm
; first layer extrusion width = 0.60mm
Re: Pendant
Navkram wrote:I change the size and scaled it up 1.5 and in netfabb i chopped the bottom point off to have a little more contact to the bed and printed with ABS here is the pick still on my Orion. no support
I use Netfabb basic to scale and to repair .stl files but I am not familiar with how the part can be edited, like chopping the bottom point off. Could you explain how to do that or does that require the pro version of Netfabb?
Navkram
Re: Pendant
Post by Navkram »
nope the free version, it really works backwards of what you think it should.
open the file in netfabb, on the right side you will see a X Y Z with sliders with a title of Cuts. with this file i wanted to slice it on the Z so you grab the slider and start to move it and a cutting plane will show up on the part, just move that up and down till you get it where you want. then click on execute cut. and then the menu will change and select "cut" deselect the part and you will see 2 parts now select the bottom and delete it.
hopefully I explained that good enough to give you a idea.
Re: Pendant
Navkram wrote:nope the free version, it really works backwards of what you think it should.
Thank you, I have seen the arrows but never used them. Now with your fine explanation, I will give them a try. Thanks!
Batteau62
Re: Pendant
Post by Batteau62 »
Orenfor
Re: Pendant
Post by Orenfor »
wow cool, can you share the stl file please?
Navkram
Re: Pendant
Post by Navkram »
here is the stl file that I used.
http://www.thingiverse.com/thing:229549
and yes it still turns on the inside not smooth enough yet to blow on it to get it to spin but by hand the spiral will turn.
Re: Pendant
Batteau62 wrote:Here's a link to a tutorial: http://www.3dgeni.us/trimming-objects-w ... dio-basic/
Thanks for that link. You are awesome, I never thought there would be a tutorial for that.
