I2C pins
The RAMBo board is finally here, and here's a place to talk about it!
cambo3d
I2C pins
Post by cambo3d »
can someone tell me if their rambo 1.1 version has an I2C connector.
If not what would be good connector to place here? links to it. What's it called?
Looks like I could probably use the same type of connectors that connect the stepper motors. What are those called?
[img]http://reprap.org/mediawiki/images/5/5c ... nn-all.jpg[/img]
gabrielk
Re: I2C pins
Post by gabrielk »
According to this http://reprap.org/mediawiki/images/7/75 ... ematic.png
SDA is on Pin 20
SCL is on Pin 21
just like in Arduino Mega
in the bottom right corner you have schematic of I2C
I have 1.0 and i also have only spots for soldering.
Just curious, what you want controll by it, and by what?
gabrielk
Re: I2C pins
Post by gabrielk »
cambo3d
Re: I2C pins
Post by cambo3d »
Planning my build and I have an lcd control panel coming that is wired through I2C.
http://www.panucatt.com/product_p/vikilcd.htm
Looking at the configuration for marlin. It looks like it has the files to support it. This works with the ramps and arduino combo as plug and play so I'm hoping it will be the same for the Rambo.
Maco
Re: I2C pins
Post by Maco »
Hi i want to know if its possible to extend the capability of the rambo via I2C to control 2 more extruders, Im looking to control this beast
http://e3d-online.com/The-Kraken
I see some pwm extension and more extension capabilities for the rambo just want to be sure if I can use the kraken with this boars
Thankss
Re: I2C pins
Maco wrote:Hi i want to know if its possible to extend the capability of the rambo via I2C to control 2 more extruders, Im looking to control this beast
Thankss
Here are three topics that discuss the E3D and the Kraken, perhaps you can join one of these discussions.
http://forum.seemecnc.com/viewtopic.php?f=54&t=3714
http://forum.seemecnc.com/viewtopic.php ... 2&start=60
http://forum.seemecnc.com/viewtopic.php ... 7&start=10
Maco
Re: I2C pins
Post by Maco »
Thanks
bubbasnow
Re: I2C pins
Post by bubbasnow »
here is a pwm shield that works with i2c
http://www.adafruit.com/products/815
Return to “RAMBo”
