Getting an Accurate Hot end Temp?
- analog_banana
Apparently it's really important to have an accurate idea of what temperature your hot end is.
I know how to measure my true hotend temp by putting a thermocuople down into the nozzle.
Once I know the difference between true temp and the temp reported by the thermistor -
how do I recallibrate the machine to include this offset?
Is there an amount I can enter it somewhere in the firmware?
Or is this something to do with "thermistor tables"???
Ho Hum...
Rostock Max MDF Kit purchased from Creative Machines UK April 2013
RAMPS 1.4
EZStrruder
SeeMeCNC Bowden Hotend V1
Onyx
Fware: Repetier 0.91
Sware: Repetier-Host V0.95D
RAMPS 1.4
EZStrruder
Onyx
- analog_banana
Re: Getting an Accurate Hot end Temp?
Well I found out how to do this after a long time searching...
There is a post - I think by a staff member, buried in this forum:
http://forum.seemecnc.com/viewtopic.php?f=48&t=1650
This shows how to compensate for an inaccurate thermistor reading in firmware.
Maybe seemeCNC should write up a manual for Rostock max calibrating?
GeneB's guide is fantastic, but surely an official manual by the manufacturer,
including stuff like this would be a good move?
There seem to be so many "secrets" I have had to discover to get this machine working.
I would rather just RTFM than Search TF Entire Forum every step of my kit build.
Ho Hum...
RAMPS 1.4
EZStrruder
Onyx
RAMPS 1.4
EZStrruder
Onyx
- analog_banana
Oh.... repetier firmware only
I guess it can't me done until I upgrade..
Ho Hum...
RAMPS 1.4
EZStrruder
Onyx
RAMPS 1.4
EZStrruder
Onyx
It would be impossible to write a manual that covers every possible question or scenario that comes up.analog_banana wrote:Well I found out how to do this after a long time searching...
Searching the forums is a necessary evil. One thing that makes it easier is to use Google to search the forum
where you would go to Google and type in site:forum.seemecnc.com search term (the words search term can be anything you are searching for)
Google will then search the entire forum search for the words you are looking for. A lot easier than using the forum search functions.
- analog_banana
Thanks Eaglezsoar,
Of course I agree with you: an infinite manual, containing the answers to all possible questions, is not feasable or desirable.
I'm am surprised that all the great information here - much of it provided by your good self - on top of GeneB's already excellent manual -
has not been gathered into a new PDF for newbies like myself.
I had a look at examples of manuals for some other machines:
If anyone else is looking for a an in-depth guide to print settings, I can heartily recommend the "LulzBot_TAZ-User_Manual-ebook.pdf".
I know it's not for delta printers, but it's "slic3r in Depth" chapter is a really good walkthrough of print techniques with slic3r.
Ho Hum...
RAMPS 1.4
EZStrruder
Onyx
RAMPS 1.4
EZStrruder
Onyx
I downloaded the Taz User Manual and it does have a good chapter for Slic3r. Thanks for the tip!analog_banana wrote:Thanks Eaglezsoar,
As a reminder, Geneb has an excellent Slic3r usage guide as part of the assembly manual. If you take a look it has info that is not in the Taz manual.
There's also a wiki for SeeMeCnC (wiki.seemecnc.com) that's been relatively recently created. It's still lacking details but would be a good place to start adding some of these "tips". Feel free to add tips you've found and expand on what's on the wiki.analog_banana wrote:Thanks Eaglezsoar,
- analog_banana
I managed to find some settings that matched my macine's thermistor readings to my real-world thermocouple readings
+/- 1degree for the Hotend
+/- 5 degrees for the bed
Here they are in Marlin:
// 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan) (4.7k pullup)
// 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
#define TEMP_SENSOR_0 5
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_BED 6
After these firmware changes my PID tuning was much more stable and repeatable.
And.. that's how I calibrated my temperatures.
Ho Hum...
RAMPS 1.4
EZStrruder
Onyx
RAMPS 1.4
EZStrruder
Onyx
One thing that I would caution is that, yes, accurate temperatures are helpful, BUT printing temps are a bit of an art form in finding that requires a bit of practice. Filaments differentiate quite wildly as far as the temperatures they print well as even the moisture content. So a filament's temperature may vary even as the roll goes along. Do not get too worked up on needing to print at 5 degrees cooler or hotter than someone else.
- analog_banana
Thanks, I agree - if the print looks good, it is good.
I'm really happy to get have a clue that my temperature is accurate now
as I can cross that off my list of what is wrong with my kit.
Ho Hum...
RAMPS 1.4
EZStrruder
Onyx
RAMPS 1.4
EZStrruder
Onyx
