Hi Guys,
I recently purchased an ezstruder but i am having a rather weird inconsistent issue, Every so often the filament will slip to the side of the gear drive and stop extruding. I can simple release the tensioner and the filament slides back into place. this is an issue if i want to leave prints alone. Anyone experience this or know how to fix it? I have tried adjusting the the position of the gear drive in numerous spots, which helped but did not eliminate the issue.
thank you!
EZstruder Issue
Re: EZstruder Issue
Make sure the hobbed bolt is in good condition, then try to increase the tension. If it chews through the filament you've gone to far, or you have a jam.
That's another thing to check is see if there's any resistance in moving the filament through the assembly without the tensioner against the filament.
