G0 and G1 dwell. . .
Hi all,
you may or may not have seen my posts about some initial issues I was having with my printer where I was getting a slight dwell between certain lines of Gcode and therefore an excess of PLA at these points where the nozzle continued to extrude. I noticed that my machine hesitated between a Rapid G0 and Coordinated G1 move. I have resolved this issue by manually by doing a find and replace in the notepad editor of Mach and substituting the G0's for G1's.
Although this is ok and I am able to get good prints, I feel that slicer should be giving me a code to use without modification - so what am I doing wrong?
Has anyone else seen this issue? Am I the only one?!
Any input would be appreciated.
Chris
Chris
Re: G0 and G1 dwell. . .
Hi,
Very interesting finding. I have a similar problem when printing in pla but i am using linuxcnc / emc2 and slicer.
I am not 100% sure it is caused by this delay but I will try and let you know.
If this is the case, a simple script could automate that task.
Could it be you guys have a lot of acceleration? Try bumping it up if you can
Im having exactly the same problem and its annoying the hell out of me, im using the find and replace trick but i really wish i ddnt have to. Im pretty sure its not acceleration but if your not having issues could you post your acceleration and feed rates?
^^ x2
I'm still rocking the find and replace trick - I have not found a solution. Getting some good prints though.
Is this still a problem for anyone else?
ive found that slic3r 0.7.1 doesnt use G0 which i was getting good results with. Ive just "upgraded" to 0.9.9 and the dwell at G0 has returned making it almost unuseable
If the first layer temperature is different than the following layer temperatures the printer waits until the temperature changes.
I keep first and following layer temperature the same In KISSlicer for that reason.
Only if you use M109 to change temperature instead of M104jesse wrote:If the first layer temperature is different than the following layer temperatures the printer waits until the temperature changes.
Ive posted this issue on the slic3r git hub page if any one feels like commenting
https://github.com/alexrj/Slic3r/issues/1212
The issue is closed on Github. Is it fixed for you in release 0.9.10b? I still seem to have pausing.Feisty wrote:Ive posted this issue on the slic3r git hub page if any one feels like commenting
This is a weird fix. G0 is causing problems and the fix is not using G0's anymore !?
I was wondering this the other day when I couldn't find any G0 in Slicer but seem them in Cura.
G0 is a valid command and shouldn't cause any pause in a motion.
I would suspect that there is a problem in the firmware.
G0 is not the same as a G1 depending on machine implementation G0 moves first in Z than in XY or full speed in XYZ.
The result is a different motion than the line of a G1.
