Any opinions on the touchless thermometers ?
I am approaching, albeit slowly, to where I can start my Calibration runs.
so, I need to purchase something. Or would the contact type be better?
touchless Thermometer opinions
Re: touchless Thermometer opinions
The infrared thermometers will not work on hotends or heat beds because they will not work on reflective surfaces.neurascenic wrote:Any opinions on the touchless thermometers ?
For accurate readings you need the contact type and I recommend that the hotend is measured by disconnecting the bowden
and inserting the thermocouple into the hotend down to the nozzle.
Whew! Glad I asked... I was just about to hit the one click purchase option on amazon.
thanks Eaglezsoar!
thanks Eaglezsoar!
Glad I got you in time. Amazon has a few meters that are less than 30 dollars, here is a link to one: http://www.amazon.com/AGPtek-Channel-Di ... uple+meterneurascenic wrote:Whew! Glad I asked... I was just about to hit the one click purchase option on amazon.
thanks Eaglezsoar!
- Captain Starfish
I had much better results unwinding the nozzle, slipping the thermocouple between it and the heat block and gently re-tightening the nozzle until it just pinched the thermocouple. Found that just shoving the lead down the filament tube led to very patchy results.
- tommee10533
- Plasticator
Acutally you can use IR pyrometers on heat beds. Just have to put a piece of black glass tape on the bed.If I recall black tape has emissivity of around 95 or so. Just get a descent one like a fluke that allows you to set the emissivity and you will get a very accurate reading.
I ordered a Contact type that I will receive tomorrow.
Thanks for the help! I shall proceed under advisement.
Thank you Thank you Thank you!
