Arduino based controller board (Duet)
JolietDelta
Post by JolietDelta »
Hey,
not sure if this is the right sub-forum, but has anyone already experience with this board(s):
http://blog.think3dprint3d.com/2013/12/ ... oller.html
The thing is that I'm planning to implement a triple or quad extruder (Kraken in this case). Dual extrusion is running fine now (with stock hot ends and ezstruder). Not that this is getting boring, but 2 or 3 colors plus disolveable support would make me even more happy. :-)
~Jens
Re: Arduino based controller board (Duet)
I have a Kraken on the way but decided to go with the Azteeg X3 Pro board that supports 5 extruders too.
I think Xnaron ordered one to see if the firmware running on the faster ARM will improve an issue he/we seem to be having with our prints showing a vertical pattern on the prints.
JolietDelta
Ok. I see...
So it boils down into porting repetier (which contains some routines in assembler) vs. 8-Bit AtMega (which will run without changing repetier).
Are you running the SD8825 in 1/32 microstepping?
~Jens
I'm waiting for my X3 Pro - I just ordered it on Sunday. But, 32 micro steps is interesting and I'll certainly try it!
Things are changing rapidly, every month something new and cool pops up!
Return to “The Lounge”
