A few bits testing out new filament
tc3jg
Post by tc3jg »
Been testing out some new filament from jagprint. A less expensive option from what's out there on the market. The company still has some adjustments to make but it's descent stuff.
Still need to do some better extruder calibration
[img]http://i292.photobucket.com/albums/mm22/tc3jg/3D%20print/63B97FF9-9E3A-4623-8BB9-07355438AE09_zpseehharjk.jpg[/img]
The finished cup
[img]http://i292.photobucket.com/albums/mm22/tc3jg/3D%20print/98A8CDD5-C11F-4B10-82B0-8F484CBDF97B_zpsijyjby3u.jpg[/img]
In process
[img]http://i292.photobucket.com/albums/mm22/tc3jg/3D%20print/th_CF78928E-84D2-4BFF-AEDA-DB6C2A8988FB_zpsz3rclm9g.jpg[/img]
Not bad for not adding support.
Also did a two tone vase the clear is from an eBay seller. This was my first stab at two colors and pausing a print I want to start putting it in the GCode as the head melts as it sits while in print
Re: A few bits testing out new filament
I like the vase, those two tones can't be easy to do.
Great job!
tc3jg
Post by tc3jg »
Thanks Eaglezoar I'm learning slowly but surely. Surely need to figure a way to get more a uniform heated bed. my print area is limited due to the warping.
tc3jg wrote:Thanks Eaglezoar I'm learning slowly but surely. Surely need to figure a way to get more a uniform heated bed. my print area is limited due to the warping.
You've tried the hair spray, the glue sticks, the dissolved ABS glue for limiting the warpage? One of them should be of help plus the printing of a brim.
tc3jg
Post by tc3jg »
Yeah gave them all a shot, glue sticks was the worse hairspray did pretty good but ABS juice is by far the best at limiting the warpage.
Nice on most of those prints. I like that skull.
