Auto-Tune and Dual Hotends (?)
Bill Havins
Post by Bill Havins »
Hello to all,
I have my dual Steve's Extruders mounted on my Rostock MAX and, after correcting a pair of really strange pin #defines in calibration.h (Repetier .83) I now have all of the hardware working and responding to manual control.
After getting everything working, I ran Auto-Tune in Repetier Host (M303 S200) and quickly realized the command did not apply to the second hotend. Is there a method/command that will run Auto-Tune on the second hotend in a pair? I referred to every online resource I know and I could not see that the subject has ever come up.
Thanks in advance for your thoughts!
Bill
Re: Auto-Tune and Dual Hotends (?)
Bill, the command for the first hotend would be:
M303 E0 S200 C5
This will heat the first nozzle (E0), and cycle around the target temperature 5 times (C5) at the given temperature (S200) and return values for P I and D.
The Second hotend would be:
M303 E1 S200 C5
This will heat the second nozzle (E1), and cycle around the target temperature 5 times (C5) at the given temperature (S200) and return values for P I and D.
Bill Havins
Thanks for the reply, Eaglezsoar. But, alas and alack ( :roll: ) the E1 entry has no effect in the M303 command (at least with my present firmware it doesn't). All of the g-code references I found (eg, http://reprap.org/wiki/G-code) do not provide a method for selecting a specific extruder. What am I missing? :?:
Bill
Bill Havins wrote:Thanks for the reply, Eaglezsoar. But, alas and alack ( :roll: ) the E1 entry has no effect in the M303 command (at least with my present firmware it doesn't). All of the g-code references I found (eg, http://reprap.org/wiki/G-code) do not provide a method for selecting a specific extruder. What am I missing? :?:
Bill
I think it was for a version of Marlin now that I went and read it again.
According to Repetier documentation it is M303 P1 to tune 2nd hotend. Here is the reference:
http://www.repetier.com/documentation/r ... tallation/
http://forums.reprap.org/read.php?267,188487
M303 P0 S230 for the first extruder
M303 P1 S230 for the second extruder, and
M303 P2 S110 for the Heat Bed.
Bill Havins
Thanks again. I'll try it and report back.
Bill
Bill Havins
Excellent, excellent, excellent! Thanks so much, Eaglezsoar!
Bill
Bill Havins wrote:Excellent, excellent, excellent! Thanks so much, Eaglezsoar!
Bill
Ask and ye shall receive! :lol:
bubbasnow
Post by bubbasnow »
Bill
i could really use a million dollars....
bubbasnow wrote:
Bill
So could I. When my request gets granted you will be next in line. ;)
Return to “Rostock MAX”
