Also, copy and post your slicer settings from the g-code. That info will let the group see what fine tuning you need to get infill and perimeters to touch better.
wildideas1 wrote:back to re calibration .7 noz printed test cube 20x20 looks beautiful Kiss setting included. BUT i have questions
1. what causes the lift in the corner where it starts the next layer and how do you stop that
2. why and what would cause the cube to be outa sq. 20.03 x 19.46mm
3. in Kiss where is the multiplier setting still trying to figure that out from begging thread in this post KISSlicer - PRO
; Windows
; version 1.1.0.7
; Built: Mar 14 2013, 14:10:34
; Running on 4 cores
; Saved: Tue Feb 11 10:58:35 2014
; '20mm_cube (1) 7noz v3.gcode'
; *** Printer Settings ***
; printer_name = Rostock MAX
; bed_STL_filename = /Users/mhackney/Desktop/3DPrinting/RostockBuildPlatform.stl
; extension = gcode
; cost_per_hour = 0
; g_code_prefix = 4732380A4D31303420533C54454D503E0A4D31393020533C42454454454D503E0A4D31303920533C54454D503E0A4D34322050362053323535
; g_code_warm = 3B2053656C6563742065787472756465722C207761726D2C2070757267650A3B2035442D7374796C650A543C4558542B303E0A4D31303420533C54454D503E0A
; g_code_cool = 436F6F6C2047436F64650A3B2047756172616E746565642073616D652065787472756465722C20636F6F6C696E6720646F776E0A3B2035442D7374796C650A4D31303420533C54454D503E0A
; g_code_N_layers = 3B204D617962652072652D686F6D652058202620593F
; g_code_postfix = 4731205837302059302046353030300A473238
; post_process = NULL
; every_N_layers = 0
; num_extruders = 1
; firmware_type = 2
; add_comments = 1
; fan_on = M106
; fan_off = M107
; fan_pwm = 1
; add_m101_g10 = 0
; z_speed_mm_per_s = 15
; z_settle_mm = 0
; bed_size_x_mm = 280
; bed_size_y_mm = 280
; bed_size_z_mm = 300
; bed_offset_x_mm = 0
; bed_offset_y_mm = 0
; bed_offset_z_mm = 0
; bed_roughness_mm = 0
; travel_speed_mm_per_s = 500
; first_layer_speed_mm_per_s = 10
; xy_accel_mm_per_s_per_s = 1500
; lo_speed_perim_mm_per_s = 10
; lo_speed_solid_mm_per_s = 10
; lo_speed_sparse_mm_per_s = 10
; hi_speed_perim_mm_per_s = 30
; hi_speed_solid_mm_per_s = 30
; hi_speed_sparse_mm_per_s = 30
; ext_gain_1 = 1
; ext_material_1 = 1
; ext_axis_1 = 0
; ext_gain_2 = 1
; ext_material_2 = 0
; ext_axis_2 = 0
; ext_gain_3 = 1
; ext_material_3 = 0
; ext_axis_3 = 0
; model_ext = 0
; support_ext = 0
; support_body_ext = 0
; raft_ext = 0
; solid_loop_overlap_fraction = 1
; *** Material Settings for Extruder 1 ***
; material_name = ABS-Black
; g_code_matl = 3B204D617962652073657420736F6D65206D6174657269616C2D737065636966696320472D636F64653F
; fan_Z_mm = 0
; fan_loops_percent = 0
; fan_inside_percent = 0
; fan_cool_percent = 0
; temperature_C = 220
; keep_warm_C = 175
; first_layer_C = 220
; bed_C = 100
; sec_per_C_per_C = 0.00681818
; flow_min_mm3_per_s = 0.5
; flow_max_mm3_per_s = 10
; destring_suck = 1
; destring_prime = 1
; destring_min_mm = 1.5
; destring_trigger_mm = 10
; destring_speed_mm_per_s = 20
; Z_lift_mm = 0
; min_layer_time_s = 10
; wipe_mm = 2
; cost_per_cm3 = 0
; flowrate_tweak = 1
; fiber_dia_mm = 1.72
; color = 0
; *** Style Settings ***
; style_name = .7 Nozzle - Infill 50% - .35mm Layers
; layer_thickness_mm = 0.45
; extrusion_width_mm = 0.7
; num_loops = 1
; skin_thickness_mm = 0.7
; infill_extrusion_width = 0.77
; infill_density_denominator = 11
; stacked_layers = 1
; use_destring = 1
; use_wipe = 1
; loops_insideout = 0
; infill_st_oct_rnd = 0
; inset_surface_xy_mm = 0
; *** Support Settings ***
; support_name = sample support
; support_sheathe = 0
; support_density = 0
; support_inflate_mm = 1
; support_gap_mm = 0.5
; support_angle_deg = 0
; support_z_max_mm = -1
; sheathe_z_max_mm = -1
; raft_mode = 1
; prime_pillar_mode = 0
; raft_inflate_mm = 1
; *** Actual Slicing Settings As Used ***
; extrusion_width = 0.7
; num_ISOs = 1
; wall_thickness = 0.7
; infill_style = -1
; support_style = 0
; support_angle = -0.1
; stacked_infill_layers = 1
; raft_style = 1
; extra_raft_depth = 0
; oversample_res_mm = 0.125
; crowning_threshold_mm = 1
; inflate_raft_mm = 1
; inflate_support_mm = 0
; model_support_gap_mm = 0.5
; support_Z_max_mm = 1e+020
; sheathe_Z_max_mm = 0
; Speed vs Quality = 0.50
; *** G-code Prefix ***
thks
i was thinking that the lifted corner cause was z-lift.. my thought as it finished a layer it lifts high, and causes that raised corner. but because you say its at 0 nothing that would do that comes to mind. a wipe would probably help but if your following the directions in the thread i wouldn't worry about it right now.wildideas1 wrote:Bubba I was following the thread calibration settings and I have z at 0 which lead to my ?
I printed again at 100% infill and while printing looked like it would be overfilled but came out better than I think I will take pics in am and post next print willbe 50% and see what I get. Still not sure of all the settings 90% dont make any sense as to what they mean or even effect . But willing to learn and never to old to try
Probably because your towers are not exactly 120 degrees to each other.wildideas1 wrote:? 1 why is my cube not sq 20.03 x 19.83 I have printed 3 cube now different infill but all 3 are exactly the same deminsions (freaky) but still not sq. Why?
Thanks to your instructions, My 20x x20 x .45mm cube is putting out a wall of.45 with a multiplier of.8676. The cube however, measures 19.6 x 19.6Polygonhell wrote:Layer alignment looks good, IME printers tend to print slightly undersized.
You can adjust the X/Y size by changing the delta arm length in the firmware, I increased it slightly I think. Z ought to be spot on because it's direct translation of the belt motion.
The detaching could just be not printing quite hot enough, ABS in particular will delaminate if you print it 5 or 10 degrees too cold.
