mhackney wrote:dpmacri wrote:Yeah, they're tough little buggersmhackney wrote:Have you ever tried to move a stepper that is powered up? You have to overcome the holding force which is quite high on these little buggers. The "retract" that I observe is a lot more than the spring effect of compressed PLA could provide. It's an odd thing!. But perhaps the skipping is due to an overheated mosfet and so the motor loses all of it's holding power momentarily while the mosfet shuts itself down for a split second
Well, I've been running 100% reliably now and feel confident (after some confirming tests) that I know the root cause of my and probably other's EZStruders skipping steps. The culprit? heat! My attempt to install a heatsink on the extruder driver was almost a disaster but luckily I did not do damage to my RAMBo. But, I did remove it. I then installed a 40mm fan in the cutout LCD opening in the door in the chamber when're the RAMBo resides:
[img]http://mhackney.zenfolio.com/img/s10/v9 ... 8937-4.jpg[/img]
This fan is wired to my E3D barrel fan on a switch so I turn it on when I start up and leave it on all the time. The fan is simply glued into the slot, it is almost a perfect friction fit. Now with the fan directed at my RAMBo, the board stays cool and I've printed for 100s of hours with many looooong 16+ hour prints with no "tat, tat, tat"! And, just to verify my hypothesis, I switched off the fan part way through a print and in about 10 minutes I started hearing the "tat, tat, tats" again. I flipped on the fan, manually assisted the extruder until the RAMBo cooled and I was back into flawless operation.
Now I think the symptoms make sense, I was seeing the stepper/extruder reverse during these skipped steps. Probably the thermal shutdown shuts off power from the stepper coils allowing the compressed filament to push back, thus reversing the rotation a few degrees.
Printed all weekend including 2 12hr prints with the grey filament with no issues. This seems to have solved my skipping extruder issue , I will ALWAYS have fans running on the board. THANKS!!!
