Big Trimmer Line Trophy
cope413
Post by cope413 »
Made a trophy for our annual golf championship.
It's large.
Came out really well.
Re: Big Trimmer Line Trophy
That's too funny! Print your own trophies. Now you don't even have to participate to get a trophy!
Generic Default
Post by Generic Default »
Probably a dumb question, but it looks like that layer between the curvy cup part the cylindrical base split and delaminated. Is it supposed to look like that?
Check out the Tri hotend!
McSlappy
Post by McSlappy »
I like your ringlight there Cope, you made that or order it?
Sonrisa3D
Post by Sonrisa3D »
This is awesome.
Tinyhead
Post by Tinyhead »
Nice that it turned out so well. Have many problems running the trimmer line? I've read that it can be destructive on the hot end. But that might only be if there is the PTFE tubing?
Tinyhead wrote:Nice that it turned out so well. Have many problems running the trimmer line? I've read that it can be destructive on the hot end. But that might only be if there is the PTFE tubing?
That is correct, you need the all metal hotends such as the E3D. The nylon requires temperatures that will melt the Peek and ruin the PTFE.
cope413
Post by cope413 »
Generic Default wrote:Probably a dumb question, but it looks like that layer between the curvy cup part the cylindrical base split and delaminated. Is it supposed to look like that?
It didn't delam, but there is a weird perimeter on that first layer that didn't stick. About 20mm of it didn't stick to the base, for some reason. The rest printed perfectly. I cut it off post-print and you can't tell.
Weird.
I coated it with a flexible rubber spray, and it's getting a couple coats of paint to look like a worthy trophy for our annual golf tournament.
I'll post pics when finished.
