Cheap nylon snap crackle pop.
mrbi11
Post by mrbi11 »
I finally took the plunge to try nylon.
Specifically I am trying the blue weedeater nylon, the brand recommended elsewhere on this forum from Amazon.
Some good stuff, it doesn't flake off even when its jammed, like my abs does.
Not so good, there seems to be a delay from starting the extruder till it starts coming out, much more than with ABS.
It is also very slippery, so my extruder is having a hard time pushing it in.
The killer is it makes snap crackle pop constantly. Sounds like tiny firecrackers, even little puffs of smoke.
The nylon laid down looks bubbly.
Varied temperature from 230 to 260, printing at about 245.
So, anyone have this?
I'm thinking a) they changed the composition of the nylon and added some kind of filler,
or b) the nylon has absorbed water from the air
or c) I'm totally wrong about both a and b.
Anyone run into this before?
Anyone run into the nylon not feeding as well as abs? Even when I added some pressure, it tending to slip.
As always, thanks for any thoughts you have to share.
bubbasnow
Re: Cheap nylon snap crackle pop.
Post by bubbasnow »
nylon is good at absorbing moisture. do a search for nylon on here they have baking directions
mrbi11
Post by mrbi11 »
bubbasnow wrote:nylon is good at absorbing moisture. do a search for nylon on here they have baking directions
Found one. Thanks!
Gonna go cook my nylon
Maybe just set it on broil and speed it up :-)
bubbasnow
Post by bubbasnow »
Found one. Thanks!
pour gas on it?
There is a multi-page topic on printing with line trimmer nylon at http://forum.seemecnc.com/viewtopic.php ... llplastics
That popping and hissing is caused by water in the nylon, read the above topic, it is quite interesting.
