Made a trophy for our annual golf championship.
It's large.
Came out really well.
Big Trimmer Line Trophy
cope413
Re: Big Trimmer Line Trophy
That's too funny! Print your own trophies. Now you don't even have to participate to get a trophy!
- Generic Default
Probably a dumb question, but it looks like that layer between the curvy cup part the cylindrical base split and delaminated. Is it supposed to look like that?
Check out the Tri hotend!
McSlappy
I like your ringlight there Cope, you made that or order it?
This is awesome.
Nice that it turned out so well. Have many problems running the trimmer line? I've read that it can be destructive on the hot end. But that might only be if there is the PTFE tubing?
That is correct, you need the all metal hotends such as the E3D. The nylon requires temperatures that will melt the Peek and ruin the PTFE.Tinyhead wrote:Nice that it turned out so well. Have many problems running the trimmer line? I've read that it can be destructive on the hot end. But that might only be if there is the PTFE tubing?
cope413
It didn't delam, but there is a weird perimeter on that first layer that didn't stick. About 20mm of it didn't stick to the base, for some reason. The rest printed perfectly. I cut it off post-print and you can't tell.Generic Default wrote:Probably a dumb question, but it looks like that layer between the curvy cup part the cylindrical base split and delaminated. Is it supposed to look like that?
Weird.
I coated it with a flexible rubber spray, and it's getting a couple coats of paint to look like a worthy trophy for our annual golf tournament.
I'll post pics when finished.
