Velleman for Hotend problem
My Velleman for heated bed work really good but my Velleman for hotend doesnt work at all. I try to hook it up but hotend doesnt heat up so i take it out and try some test. The led light up but when i measure NO with ground from power supply nothing. Anyone can help plz thank you!
Re: Velleman for Hotend problem
Do you have a jumper wire from the 12V + going into the COM terminal on the relay connector? The relay is isolated from the power to the board, so you have to have a jumper from 12+ to the COM terminal, then NO will be "hot" when the LED is on, aka caling for heat
Uhhh I dont really understand what you mean coz, I solder like my Velleman for heated bed so 12V+ from power supply connect directly to COM terminal. But i just try jumper wire 12V+ terminal to COM terminal but still nothing. I suspect that the relay is death.
Hmm, do you hear it clicking when you power it on?
No clicking sound when the light on. Try my heated bed Velleman and yes it has a clicking sound but not on the Hotend Velleman
