Termistor Wire Harnesses
joecnc2006
Post by joecnc2006 »
I have had the Rostock Max for a while now and just now getting back to it to finish the heating bed and electronics.
I went to wire the heating bed up and the instructions call for two thermistor wiring harnesses. I have been very carful to keep everything in bags and together for when I would resume the build. Now I can not fine the two white wires with the connectors to the board. The wires are no big deal but the connectors are two pole and have a clip on them to lock to the board. Where can I get those, I wanted to get it all wired this weekend but looks like that is not going to happen.
Is it possible they were left out of my kit by mistake and I just never noticed?
Joe
Re: Termistor Wire Harnesses
joecnc2006 wrote:I have had the Rostock Max for a while now and just now getting back to it to finish the heating bed and electronics.
I think the part number from mouser electronics is 538-50-57-9402
joecnc2006
Those are three pin connectors I need two pin connector I will look there wish I could get them local and quick.
Edit: sorry now I see the 2P nomenclature out to the side.
Joe
joecnc2006
Another Question, What gauge wire is it suppose to be?
Joe
joecnc2006 wrote:Another Question, What gauge wire is it suppose to be?
You will also need 4 of part number 538-16-02-0096 which are the pins that accept wires from 24awg to 30awg and cost 12 cents each.
Toyguy
Post by Toyguy »
Those wires were shipped with the Rambo, so if you have any Rambo parts stashed anywhere, check those too.
joecnc2006
I have everything all together and those wires are not there.
Joe
bvandiepenbos
Post by bvandiepenbos »
Not sure, but check at your local hobby shop, they might have something that could work. Like what is called a JST connector.
Do you have any jumper wires from some other project, hot melt glue two together and make your own plug.
Wire is light guage like 24awg
A JST connector will not properly mate with the thermistor connectors on the RAMBo. The thermistor wires were included in the little Ziploc baggie that ships with the RAMBo box. It's the same bag that contained the three end sotp switches, the end stop wiring and the extra 2 and 3 pin connectors with crimp pins.
joecnc2006
geneb wrote:A JST connector will not properly mate with the thermistor connectors on the RAMBo. The thermistor wires were included in the little Ziploc baggie that ships with the RAMBo box. It's the same bag that contained the three end sotp switches, the end stop wiring and the extra 2 and 3 pin connectors with crimp pins.
hmm did not have a little bag with those, I do not have any switches other that the 3 limit switches. I just ordered three small fans one 25mm x 10mm and two 30mm x 10mm and a new LCD daughter board. I accidently soldered everything on one side of it, That's what we get when we work on it into the night, should have paid more attention.
Joe
I've never seen a RAMBo box from Ultimachine that did NOT have that little baggie. Keep searching. :)
Return to “Rostock MAX”
