First, I want to list all the things that I THINK I know, but could be wrong on. If I am wrong, please let me know:
1) All the Rostock MAX needs is plenty of +12V (the yellow wires), the associated ground wires (black), and a switch between the power line (green) and a ground. The other lines (+5V, -5V, -12V, +3.3V, sense wires, etc) can all be left disconnected.
2) All the yellow wires are the same, as are the black wires. So, you can use whichever you like and ignore the others.
So, if both of those are true, here's my plan (again, please let me know of any flaws):
1) Cut off all of the connectors, leaving the wires as long as possible
2) Collect the set of wires I actually need (from the current manual: six yellow, seven black, and a green)
3) Open up the PSU (yes, it violates the warranty, but what do you think cutting the connectors off does?), and remove every unused wire at the circuit board.
Result: no big bundle of unused wires, no risk of shorting, cleaner machine.
... sound good?
Thanks,
Dan
