I need help. I did the drawing in sketup, converted to G code by slic, and I load the Gcode MACH3. Do not adjust extrunder on the table. (G92 E0 reset extrunsion distance).
[youtube]http://www.youtube.com/watch?v=IqIjI_FBUvo[/youtube]
Help - my first drawing-Sketup-Slic-Mach3
Re: Help - my first drawing-Sketup-Slic-Mach3
I need help setting up.
In Slicer, under the printer tab, you need to choose Gcode flavor of Mach3/EMC It is exporting E codes for your extruder axis, and Mach uses A as the axis letter. Changing the gcode flavor will fix that problem.
Anytime! Glad we could help
