Ouch! 1.5mm?? That could be a problem! I would be careful with that thin of a glass. You did see correctly, I cut the glass to just the size of the silk screen.
Yeah, I kept crapping it up, for now I took an aproximately sized shard, and clamped it down with bulldog clamps -- for the long term, I ordered a piece of tempered glass, cut to size, from
Elite Custom Glass. I went for a 6" x 7.5" x 3/16" (3/16" = ~ 4.8 mm) clear seamed rectangle. The glass itself was only $20, but shipping was another ~$13.50 -- still that's not too bad, assuming it shows up in one piece.
As for why these instructions are not on the Phebe? My only guess is that there are so many and vary so much that it would be impossible to have them on there. We can print directly on the Phebe, but its not the best solution and you can use many forms of tape/coverings to get a better print.
Yeah, I mean, I'm not saying that they should provide a guide or hold my hand or anything -- but a simple "by the way, you need to insulate this from your plastic print bed, so that your printer doesn't melt (you dumbass)." would've been nice.
Anyway, I soldered, glued, taped, and heat shrinked it up today -- used 16 AWG for each of the four power terminals (had to drill the holes slightly wider for it to fit), and some random (~22 AWG) wire I had laying around for the thermistor.
Also, had to drill the mounting holes slightly wider, so I can mount it to 1/4" plywood (like what you did) but with some #6-32 screws and locknuts. And I cut out a small little notch underneath the solder pads, about 3/16" in from the edge (not shown), so that the wires wouldn't be smashed up against the plywood.
I might also glue down an acrylic sheet (or maybe some lexan) to the old print bed, similar to what you did (not sure what materials you used) -- mostly, I just don't like that the mounting screw holes are so close to the edge of the regular print bed. Anyway, wikipedia says acrylic should be good to 160 °C, and google says Lexan melts at 140 °C, considering there will be wood and an air gap, and those are probably my max temps anyway, I think either should be okay, don't you? Otherwise I might just go with a second piece of wood!
You can see it attached to the wood here, and the closest-to-correct-size shard of glass I could make:
[img]
https://p.twimg.com/A1r-V2_CEAEtUU_.jpg:large[/img]
Here's the wiring, glue, and tape, and what not -- decided to go with a red LED to signify "danger":
[img]
https://p.twimg.com/A1vv7KxCAAAMqjR.jpg:large[/img]
