[ENDED] Free $150 from Misumi for first time customers
Eric
Re: Free $150 from Misumi for first time customers
Post by Eric »
Barefoothurst wrote:Check this out. I think it's the same but I haven't checked the exact specs.
http://us.misumi-ec.com/vona2/detail/110300465870/?rid1
No, that stuff is 15mm x 15mm, same as Openbeam. It's what the mini-kossel uses. You could make a max-sized machine from it, but it wouldn't be as stiff.
The Rostock Max clearly uses a larger size, since it uses T-nuts, not sure exactly which. I don't own a Max to check.
JD79
Post by JD79 »
I want to say it falls into the 2525 extrusion. I'm going by the 1 inch size that is being sold on seemecnc.com parts section.
-JD
Barefoothurst
Post by Barefoothurst »
Sorry for the bad info. I'm new and still learning all I can.
brent
Post by brent »
JD79 wrote:I want to say it falls into the 2525 extrusion. I'm going by the 1 inch size that is being sold on seemecnc.com parts section.
so, which 2525 exactly?
JD79
Post by JD79 »
when you configure on the left side choose width of 25 and thickness of 25 single row slot and then choose anodized or black anodized. Packing list for Max v2 shows t slot rail 1" (25mm) square x 32" (812mm) long. Picked it up from ups today.
-JD
I'm not positive, but I think SeeMeCNC use 8020 extrusions, they have a different profile than the Mitsumi ones, you might have issues with the cheap skates.
joecnc2006
Post by joecnc2006 »
Joe
brent
Post by brent »
This promotion is now over. I edited the post to reflect that so people don't waste time.
AndThenSome09
Re: [ENDED] Free $150 from Misumi for first time customers
Post by AndThenSome09 »
Good idea, thanks for that! :D
3D Printing Blog, Build, News, and Store
Come check us out @ http://www.i3dtech.net
Return to “The Lounge”
