Just received my kit - Missing Parts turned Build Discussion
whaleboy
Re: Just received my kit - missing parts.
Post by whaleboy »
Dampers... I ordered from Astroboy. He says 6x 6mm 3M screws are needed. I don't know how they compare to the cork ones, but here is a before/after for the astrosyn style...
https://www.youtube.com/watch?v=_3Xn7b7tcxY
As for the connectors, more for the heaters than the fans, but the micro deans are no bigger than the JST's. They need to be soldered, but I find that easier than trying to properly crimp the JST servo style connectors, which I've always had a hard time with (even with the proper crimping tool, and I've done quite a few in the past).
-David
atoff
Post by atoff »
whaleboy wrote:Dampers... I ordered from Astroboy. He says 6x 6mm 3M screws are needed. I don't know how they compare to the cork ones, but here is a before/after for the astrosyn style...
-David
Wouldn't 6mm be too long? http://forum.seemecnc.com/viewtopic.php ... =50#p17045 Saying 5mm with washers, because 5mm is too long. I found some 4mm screws I was thinking of getting so I wouldn't have to use washers.
whaleboy
Post by whaleboy »
Just going by what Astroboy says, but I won't know for sure until the dampers arrive. I'll wait until then before going out and getting the additional hardware. I think the one he got (in your linked post) are slightly different than the ones Astroboy is selling. I'll know in the next couple days exactly what I need and I'll report back...
-David
atoff
Post by atoff »
-David
Oh you're totally right! I completely missed that post. He's ordered a different type. I was wondering why he was calling for 12 screws, when it looked like only 6 were needed. I'll do some more reading before I order the screws.
apostoly
Post by apostoly »
atoff wrote:
-David
haha ive been thinking the same thing this whole time. glad that got spoted because i was very confused
Have you guys already built your printers? im stuck on the stepper motor mounting part because i was waiting for trick lasers parts to arrive, and now that ive re ordered Astroboys ill have to wait longer.
Think its worth waiting or will it be too much of a pain to try and slip them in after its all built?
atoff
Post by atoff »
Yup, definitely!
I'm where you are, but I'm not going to continue the build until the dampers arrive. Don't see it worth the hassle of having to disassemble, when they'll be here in 4 days. Looks like it wouldn't be possible to just slip them in.
apostoly
Post by apostoly »
Yup, definitely!
Yea fair enough, already received tracking details so pretty happy i purchased from these guys. thanks once again!!
I'm in Australia so everything take a lot longer. The fastest things to get here was the printer itself - 3 days!
atoff
Post by atoff »
apostoly wrote: Yea fair enough, already received tracking details so pretty happy i purchased from these guys. thanks once again!!
Very cool, I received a tracking number too. :D Of course it's only about 900 miles from me.
Anyway, 6mm looks like it'll work... http://forum.seemecnc.com/viewtopic.php ... =30#p17566
Also looks like I'll have to remove / adjust the drive gears from the motors! :( Didn't think about that... had it all finished up with thread lock.
apostoly
Post by apostoly »
yep i saw that, i already had to get the hairdryer out because one of the gears wasn't on flush, so here we go again.
Ive had the printer sitting in my room in this unfinished state since last monday. I WANT MY PARTS haha
Anyways, Good luck with it all
Paul
edge922
Post by edge922 »
Does anyone with the dampers installed notice a difference in print performance? Any concerns about the flexibility of the motor mount being translated to the belt/arms?
Follow My Rostock MAX V2 Build in progress.
atoff
Post by atoff »
apostoly wrote:
atoff wrote: yep i saw that, i already had to get the hairdryer out because one of the gears wasn't on flush, so here we go again.
Paul
I hear you! I guess it's not a bad thing my thermistors were missing though, gave me a chance to learn about these upgrades.
And thanks, good luck to you too!
Alex
atoff
Post by atoff »
So, I contacted the seller of the Meanwell SP-750-24, he relisted it for me so I could "Buy it Now." Total shipped was $53.67, so a pretty good deal! I could have gotten it for $3 less in fact, but I loathe Fedex Smart Post, which was the other economy option... I just chose standard USPS... 11th-19th estimated delivery, which is fine by me, since I still have to search for a SSR and figure out a few other things. $60 would have been Priority, which would have it here before the end of the week.
atoff wrote:So, I contacted the seller of the Meanwell SP-750-24, he relisted it for me so I could "Buy it Now." Total shipped was $53.67, so a pretty good deal! I could have gotten it for $3 less in fact, but I loathe Fedex Smart Post, which was the other economy option... I just chose standard USPS... 11th-19th estimated delivery, which is fine by me, since I still have to search for a SSR and figure out a few other things. $60 would have been Priority, which would have it here before the end of the week.
That is a good price on that power supply, it sells at 3 times that price at other sites and is one powerful power supply. If you need more info on how to hook it up to the Onyx just ask. The fan in this
power supply is a little on the loud side as is all the heavy amperage supplys. Moving away a lot of heat means more fan noise.
atoff
Post by atoff »
Eaglezsoar wrote: That is a good price on that power supply, it sells at 3 times that price at other sites and is one powerful power supply. If you need more info on how to hook it up to the Onyx just ask. The fan in this
Thanks, I am a bit unsure of which SSR to pick up. I was going to go for one of these: http://www.ebay.com/itm/New-Solid-State ... 2ec9917e59, but not sure if there's enough overhead at 25A... so I was instead looking at this one: http://www.ebay.com/itm/1pcs-Soild-Stat ... 2a3a03d027. Do you think that would be a better choice? Also, definitely, if you have a link or discussion on hooking it up, would totally appreciate it.
I like this one because it is rated for higher amps and is in the United States instead of China. http://www.ebay.com/itm/1pcs-Soild-Stat ... 2a3a03d027
The heatbed output from the Rambo would go to the input on the SSR. Watch the polarity when you are connecting the wires. The Positive output of the 24V power supply goes to the positive side of the
SSR and the other output screw of the SSR would go to the positive side of the Onyx. The negative side of the 24V power supply would connect directly to the negative side of the Onyx.
atoff
Post by atoff »
Yup big plus with it shipping from the U.S.... went ahead and ordered it, thanks. Next step is to find a decent heatsink. I wonder if I can modify one of the many cpu heatsinks I have lying around.
apostoly
Post by apostoly »
Let me know how you manager to remove/readjust the little toothed pulleys from the stepper motor shaft
I tried a hairdryer on the tip for about 5 mins, didn't budge with hand(wrapped with a towel of course)
The grub screws came out no problem
whaleboy
Post by whaleboy »
-David
I just noticed the hot end isn't even supposed to use the JST, instead the 4x1 snap connector, so I was mistaken on that. Oh well.
Got the Damper plates... Yup, the Astroboy set just uses 2 m3 x 6mm screws to hold the motor, and the plates can be attached to the board with the same 10mm screws used for the motor in the stock config.
In checking I noticed one of the motor connectors has a big blob of glue at the end, covering one of the guide tabs, and it actually goes into one of the lead holes. If I did enough scraping/filing I suppose I could clean it up enough to make it usable again, but it looks like the connector is the same one suggested for use on the hotend. If so, the ones I ordered as suggested by the manual should arrive Friday. Are they the same 1x4 connectors? If so, lucky I ordered extra.
-David
whaleboy
Post by whaleboy »
Polygonhell wrote:Word of warning about replacing the PSU, some ATX PSU's (often the better ones) require a significant load on the 5V line before they will deliver a consistent 12V.
If I were replacing the PSU, I wouldn't swap it for another ATX PSU.
What would your suggestion be?
-David
atoff
Post by atoff »
apostoly wrote:Let me know how you manager to remove/readjust the little toothed pulleys from the stepper motor shaft
Did you put too much loctite on the grub screws? The pulley's went on a little tight on a couple of the motor shafts, so I can imagine it would be difficult to remove if they were also glued in place with the loctite. The pic in the manual has far too much in my opinion. I don't think it should ooze out like that. I put just a dot on each grub screw then twisted each in my fingers to spread it thin. I haven't tried removing the pulleys yet, but will do tomorrow morning. But may want to try some isopropyl or acetone.
-David
-David
I can check in the morning if those connectors fit the motor connectors (if that's what you're wanting to know - sorry, lack of sleep, my brains not functioning at 100% right now :D ), unless someone beats me to it.
apostoly
Post by apostoly »
I put a single drop, maybe a little more in the actual hole then screwed in the grub screws.
I found a couple of solutions
https://www.youtube.com/watch?v=YeqVtrW8eHE
https://www.youtube.com/watch?v=wvw-jCSUT14
I dont want to damage the stepper in anyway so ill take my time and be weary of the amount of loctite next time
atoff
Post by atoff »
Looks good, the pinion pullers look to be about $10-15 on Ebay. Mine came off without a problem luckily, a little snap of the loctite and it pulled off. I measured the pulley gear at 14mm, so I'm just going to mark the shaft at 8mm from the top and install the pulley gear so that the bottom is to the mark. That would leave it raised the 6mm mentioned in the other thread.
-David
Okay, so I checked the connectors, and they are in fact the same, so you should be good.
atoff
Post by atoff »
Question... is this wiring correct for the 24V power supply + SSR? Also, wondering, does it matter that the thermistor in my heat bed is different than the thermistor I'm using for the hot end? I'll be using the screw-on thermistor for the hot end.
[img]http://i.imgur.com/0cVz1sq.jpg[/img]
bubbasnow
Post by bubbasnow »
atoff wrote:Question... is this wiring correct for the 24V power supply + SSR? Also, wondering, does it matter that the thermistor in my heat bed is different than the thermistor I'm using for the hot end? I'll be using the screw-on thermistor for the hot end.
careful, i purchased one of these from amazon and after only 20 minutes of use it was stuck in the on position....very scary!
atoff
Post by atoff »
You know, I've been worried about that! I've been reading reviews mentioning the same thing. I'm starting to feel like I should just run it directly through the Rambo. Do you have any suggestions on what to do? I'm not able to find a better SSR. If I ran it straight through the Rambo... do I need to make any changes?
Return to “Rostock MAX v2”
